Has anybody had to change the rear pipes, and if so what material did you use, just been crawling under mine doing the steering rack bushes(about time they were done), and noticed that the pipes are corroded.
Rear Heater Pipes.
It has a rubber section for about 18 inches and then metal under the footwell up the bulkhead.Originally posted by RobLast time i looked, mine were rubber hoses, i think. Tried to disconnect them to flush out the rear heater once, but they wouldn't come off the short metal stumps that stick thru the floor! (these the bits you're referring to?)
