can someone help me. my surf has a grinding and clonking sound when i turn hard right.the sound seems to be in the transfer box.when i go into 4 wheel drive high the 4wd light does not come on and it seems to slip out.can someone help.
can someone help
Originally posted by gordoncan someone help me. my surf has a grinding and clonking sound when i turn hard right.the sound seems to be in the transfer box.when i go into 4 wheel drive high the 4wd light does not come on and it seems to slip out.can someone help.
Hope your not putting it in 4wd on tarmac????I'm a custard donut monster
clonking is usually worn CV joints, grinding....wheel catching on full lock?
..might be hub problems, do you have any 4x4? or is it just jumping out on full lock?VW Taro (hilux single cab PU) - 31" rubber, H/D springs and shackles, LSD, 4 pot front callipers, 2.4 N/A Flymo engine..
getting new steering stop caps.yes have 4x4 in low but seems like not in high no 4wd light on dash in high.Originally posted by ja1983clonking is usually worn CV joints, grinding....wheel catching on full lock?
2nd Gen and 4x4 on road... and why not to do it...
taken from http://www.toyotasurf.asn.au/techsite/downloads.htm
ARTICLES & STICKERS
Sunshade Lube Points
File size: 221KB
DOWNLOAD PDF document
Sunvisor Car Translated
File Size: 55KB
Sunvisor Sticker Translated
File size: 31KB
got new steering bump stop caps and greased up and problem sorted thanks all for help
because doin so causes what is known as axle wrap, basically when i 4wd and when turning, all four wheels are trying to turnat different speeds, as there is no central diff, it basically has to drag a wheel round = lots of stress on cv joints and shafts!Originally posted by gordonthis is my 1st 4x4 why not put it in 4wd on tarmac
lots of info and technical stuff explained HERE!VW Taro (hilux single cab PU) - 31" rubber, H/D springs and shackles, LSD, 4 pot front callipers, 2.4 N/A Flymo engine..
