My 2" lift springs have lost there lift under any load so have just ordered these.
Firestone Coil-Rite Kit
Each kit is complete with air springs, air lines, inflation valves,
supports, mounting hardware, and detailed installation manual.
Durable polyurethane air springs will support 500-1000 lbs per set.
Provides load support through the use of air pressure.
Mounts inside an existing open coil spring suspension.
Increase vehicle stability.
Improve steering and balance.
Improve braking effectiveness.
Prevent "bottoming out".
24 months or 24,000 miles (whichever comes first) warranty.
and reckoned on some uprated springs but I'm pretty sure I wont be up to fitting them myself. You still have to remove the springs to slot in the air-springs I assume.
if at first you dont succeed..... bollock
