HELP 1994 3.0ltr automatic gear box intermittant problem. It will not change up into top gear and you have to rev higher than normal to make it go up through the other gears. checker o/d button and a it is engaged. i have twice taken it to a specialist who has cleaned all electrical connections but no problem found and the box worked fine for 10 days untill the same problem returned. cleaned connections again and it is working now, but they could not actually find a problem. any ideas. could it be something to do with the throttle possition sensor ????
