Help Just Bought A 1991 Surf 2.4 T Diesel With A Known Oil Leak (from Auction!!!)
On Forst Inspection On The Car The Top Brather Pipe Has Been Removed From The Rocker And Left To Dangle And The Rocker Has Had A Pipe With A 3 Inch Bolt Init Blocking The Hole???why Is This
So I Left It There And Proceded On The Way Home
On The Way Hole The Oil Leak Was Pretty Bad Causing Me To Keep Stopping And Top It Up
On The 2nd Top Up Stop It Was Bubbling Water And Leaking Water Pretty Bad
I Have Looked For The Most Obvious Like **** In The Oil Cap But Alas Nothing
Seems Like The Oil Is Dripping Down From Something On To The Gearbox Join And May Be Causing The Clutch To Slip A Little
If Anyone Has An Idea What Common Oil Leakes These Have Please Email Me With Any Info
