Hello all, First post
(K Reg Hi-Lux 4 door pick-up 2.8 non turbo diesel)
I have a problem with my heater, which is foxing me.
I'm absolutely stumped on this one, every test I try say's it should be working but it's not, I do seem to have a flow of hot water through the matrix, so I am thinking I may have a fault with the Vent Controls?
It seems I have (all mechanical)
One control for recycling the air inside the car or have fresh air, another that controls where the flow goes and a 3rd that controls the amount of heat.
The one that controls the heat has a cable that goes to the heater valve, which does open and close and the heater valve is opening for sure (this is where I thought was going to be the fault)
The slider for the heater, never felt as though it opened anything other, there was and is a smooth movement from hot to cold.
Does anyone know for sure if the heater slider also controls if the air flow goes through the heater matrex box or does the normal cold air flow through the matrex box anway?
Thanks very much for any advise
(K Reg Hi-Lux 4 door pick-up 2.8 non turbo diesel)I have a problem with my heater, which is foxing me.
