I know a lot of you will have done this before, but I can't find an answer when I search.
When removing the front drive shafts to renew the boots, do the differential drive flange bolts come out of the drive shaft flange or are they fixed like studs, struggling to get enough room to remove the shaft, already removed the shock absorber bottom bolt and shifted the shock out of the way. Don't have heavy enough ball joint splitter to let go of the bottom ball joint to pinch some more space
cheers
John
cheers
John
[SIZE=4][FONT=Century Gothic]I can fix it...it won't be cheap.........or pretty![/FONT][/SIZE]
