i have recently bought a 3.0 hilux surf ssx when in 2 wheel drive put into gear but i have not got any drive but no problems in four wheel drive any help would be appreciated thanx
2 wheel drive problem
Originally posted by BUSHWHACKERMake sure the short lever is in 'H' or pulled back towards the centre console.
p.s. update your profile so we know what year Surf you have.
wheel drive?
Yep, but if the lever is in the middle, thats neutral and no drive, 2wd or 4wd.
Now and again when I get into the drivers seat I may inadvertently knock the small lever into neutral with my knee, start engine put it into drive, and nothing happens.
So check that first, 'cos it's a cheap fix.
Originally posted by BUSHWHACKERYep, but if the lever is in the middle, thats neutral and no drive, 2wd or 4wd.
So check that first, 'cos it's a cheap fix.Last edited by seve; 17 July 2005, 21:24.
Is the air con cold ??? If it is then most likely thing is the belts either need re tensioning or replacing.
As for the switch is it for any spot lamps on the front of the surf if so most likely they have been wired wrong
MikeI always work better wet.
Its why I became a plumber!!!
Originally posted by Mike66Is the air con cold ??? If it is then most likely thing is the belts either need re tensioning or replacing.
Mike
Yeh like Mike said, also the spots may have been removed before sale and the wire-ends might not have been insulated well enough and are shorting
And there I was reading down thru the first few posts just dying to say 'your rear driveshaft is missing' !!!!!
Mike
