My Oil Pressure Gauge Is Reading A Bit On The Low Side(1/4)on Meter,it Go's Up A Little Bit When Driveing But Not A Lot About Half Way ,but I Also Have A Small Leak Of Oil Coming From The Back Of The Rocker Box,
Could This Be The Problem?
It Is A 2.4 Auto Surf On A K-plate 93 (kn130- I Think!!)
Also:
1)is The Rocker Gasket Easy To Replace?
2)is There Somewhere I Can Print Of Details Of How To Change This?
Regards Dan
Also:
Regards Dan
shaped hole its gone!
thanken you
