help
a mate of mine has sprayed belt dressing on the tubo belt and the other belts ,fan, pump ect, and suspect its gone between the pully and bearing housing??
since hi did this theres been a rattleon the tubo unit !
this dissapears when he sprays wD 40 down the side of the pully on the turbo , sounds like a bearing rumbble to me ?
i dont think any long term damage is done. i think the tacky spray is to bame as its as quiet as a mouse when sprayed, freeing up the bearing,
should he remove the turbo pully and clean/replace bearing if so how do we remove the pully as theres a nut on there but will just turn the pully
Any info would be greatfully accepted.
