On Staturday Myself & ohsupremebeing were doing some odds & sods on the Surf & was saying that my rear end seams DRUNK as it shimmys about a bit. After having a good look around the rear axle we discovered that my rear Anti Roll Bar rubbers were worn on closer inspection it looks like theyve been like that for a good while. I really notice this while towing my 1 1/2 tonne Caravan anything over 55mph is dangerous. Toyota had a visit & i pick them up on Thursday all for £12. Its only a 5 min Job as its very easy to do.
Rear End Shimmy
Might be worth seeing if anything else is worn - I've had no rear anti roll bar on mine for a while now and I can't say I've noticed a problem with the handling (even with a mini digger behind at 55 + ish)Originally posted by markyOn Staturday Myself & ohsupremebeing were doing some odds & sods on the Surf & was saying that my rear end seams DRUNK as it shimmys about a bit. After having a good look around the rear axle we discovered that my rear Anti Roll Bar rubbers were worn on closer inspection it looks like theyve been like that for a good while. I really notice this while towing my 1 1/2 tonne Caravan anything over 55mph is dangerous. Toyota had a visit & i pick them up on Thursday all for £12. Its only a 5 min Job as its very easy to do.
Roger
The links that attach to the end seam fine i'll have a good wiggle with it when ive done it.Originally posted by GamedawnMight be worth seeing if anything else is worn - I've had no rear anti roll bar on mine for a while now and I can't say I've noticed a problem with the handling (even with a mini digger behind at 55 + ish)(\__/)
Thats one fast digger you got Roger!!!Originally posted by GamedawnMight be worth seeing if anything else is worn - I've had no rear anti roll bar on mine for a while now and I can't say I've noticed a problem with the handling (even with a mini digger behind at 55 + ish)
Tim
