Originally posted by exmee46
rattle from front
[COLOR=red][FONT=franklin gothic medium][SIZE=3]chill-out
Originally posted by ganja-1its not a theroy its a fact when i had the rattle i replaced cv joint two sets of bearings NEW driveshaft ,still a rattle( sussed the bushes when i changed driveshaft) phoned milners orderd them and after 12 months of head scratching and a few quid no rattle
Sorry for being a bit thick!
CheersMart
......surf's up pal!
Originally posted by AndyLalaI think these are the things you are looking for.
andyL
Cheers guys3.0 TD SSR-X LTD 1994 Black, sold and passed MOT
Originally posted by Damian£25 - £30 for some bronze bushes??????? I hope they're not phosphure bronze bushes at that price! Does anyone have the size of them 'cos they're bound to be cheaper at places like BSL.3.0 TD SSR-X LTD 1994 Black, sold and passed MOT
That's just crazy, not even flanged bushes are that price! I used to work for BSL, and I wouldn't be able to sleep at night if I sold 'em at the milners price........... as for Toyotas' price...!
If anyone can get the size of the bushes, then I'll give you the references so we can all get them cheaper! For the flanged type (or 'top hat' as some call them), I need the inside and outside, the length (incl flange), dia of flange and thickness.
Is there a section on this forum that gives us this info? For instance if we need wheel bearings and seals, what are the refs? I'll have a word with an old colleague this week and try and get some wheel brg catalogues off him!
£24?Damian
http://www.themudlife.co.uk
Originally posted by DamianThat's just crazy, not even flanged bushes are that price! I used to work for BSL, and I wouldn't be able to sleep at night if I sold 'em at the milners price........... as for Toyotas' price...!
£24?3.0 TD SSR-X LTD 1994 Black, sold and passed MOT
Originally posted by Dog_BookOk, my hubs are all apart having the new bushes fitted and the exsisting ones shown no sign of wear. So am i missing something??? Any tips on re-fitting the hubs with the new bushes?
Ok, new bushes fitted. And there seems to be no play now in the front drive shafts........ so hopefully its all gona be ok3.0 TD SSR-X LTD 1994 Black, sold and passed MOT
Axial play in drive shaft
Mine also makes the rattling noise - but I can only hear it with the window wound down! . The movement is along the splines - the solution is new inner and outer thrust bearings, I suspect. I need to get round to doing something about it!
Originally posted by donk70hi guys and girls.
please can you help?
i got a rattle from somewhere in the front when driving over bumps in the road and drains.been trying to avoid them cause the rattle is doing my head in.been underneath to look for rattle but cant find anything wrong.
any help would be helpfull.
thanks in advance for any suggestions.
its a 1995 model ssrx.3.0.manual model
thanks again
mark.Last edited by NickT; 11 June 2005, 18:05.
Noise has gone ! Looks like the inner needed changing only because the outer is only used for thrust. I'm sure Tony N would have something to say!!! I changed both, the outer being overpriced i think ........3.0 TD SSR-X LTD 1994 Black, sold and passed MOT
Originally posted by Dog_BookNoise has gone ! Looks like the inner needed changing only because the outer is only used for thrust. I'm sure Tony N would have something to say!!! I changed both, the outer being overpriced i think ........
Thats probably why Milners only do the inner ones.
