Rear UJ has decided to fail. I've just removed the rear prop shaft as the new UJ should be arriving at work tomorrow (hoping maintenance will volunter to fit it). I was wondering if there is an actual Torque figure that the prop shaft bolts should be tightened to?
Many thanks in advance
Duane
Duane
