Hi, don't know if this is a common fault or just a bit of wear and tear etc.
8 times out of ten when I turn the engine off the key stops on the "acc" (that's what I think it says) point. No amount of jiggling will get it to switch to off and I can't get the key out.
I have to re-start the engine and hope when I switch it off this time it goes "all the way". Took 6 re-starts tonight. Frustration is not the word !
Is it as simple as a squirt of WD40 or are there dark forces at work ???
Thanks for your help guys
Nil Illigitimi Carborundum
