Does anybody know if the rubber bushes at the inboard ends of the lower front suspension A arms, on a torsion bar sprung truck, are replaceable or do you have to replace the whole arms? just noticed mine seem to have far to much play in them!
Lower A arms
Originally posted by andycookyes they are,
how did you check for play?
jacked up truck a stuck a crow bar in the gap between metal of the arm and chassis, i'm guessing the big gap is part of the problemDiesel, like petrol only better
These look good . . .
http://www.superpro.eu.com/main.htm
When I get money I'll be doing my whole lot.
Mark:
Poly bushes are good but ride harder than rubber ones, it stiffens things up nicely if thats what you want, but may feel slightly harsh, especially if you used to the soggy old ones.
Also, don't spare the lubricant you get with them, they squeak like a bugger if they dry out! Annoys the hell out if you, believe me, been there.
Mark
Neville
was thinking of sticking with rubber bushes, had experience of the squeaks on my old leaf sprung hi lux, also found that being super dooper firm for on road handling they seemed to prevent/limit the flexibilty off road.
also just done my cv boots, not bad job, better if it hadn't started to p### down half way through. good tips on here plus haynes manual, shame my truck didn't match any of the pictures! mix of all of them????????Diesel, like petrol only better
Originally posted by openbackwas thinking of sticking with rubber bushes, had experience of the squeaks on my old leaf sprung hi lux, also found that being super dooper firm for on road handling they seemed to prevent/limit the flexibilty off road.4x4toys.co.uk - Keeping you on and off the road...
Hi All,
Neville, SuperPro list two part numbers as suitable for the front lower control arm inner bushes - this is from an email I got from Richard Fearn of SuperPro:
"SPF2028K & SPF2337K. You are correct both of these kits will replace the inner bushes on the lower control arm. SPF2028K reuses the original shells in the Toyota control arm. Each kit contains 8 ‘Top Hat’ bushes and 4 steel tubes. Each bush ‘assembly’ consists of 2 bushes & 1 tube – so therefore each kit will replace the inner bushes on the front lower control arm on each side of the car.
SPF2337K does the same job as SPF2028K but comes with replacement shells. As the shells are being replaced it is possible to modify the design of the bush into a single ‘Cotton Reel’ style to replace the two top hat bushes used for each assembly in SPF2028K. It is generally felt that a single cotton real bush will work more effectively than two top hat bushes where it is practically feasible to design it that way. However, the two top hats will still give excellent performance."
After communications with Richard & other folk at SuperPro, I understand that they have bushes to replace pretty much any chassis or suspension bush. My only problem is that I can't afford them. They'd be what I'd buy if I had cash. As it is, I can't afford anything till it breaks . . .
Mark:
Originally posted by TonyNExactly, if your building an offroader, rubber bushes are far better for flex, especially in the leaf spring bushes. I fitted used rubber ones in the 3/4 elip rear of my pick up, and it flexed nice.Roger
Mark
Interesting bit of info.I will save that for future reference.Allready got genuine replacement bushes for mine.
Neville
