I have a 96 3rd gen. Coming from the back/boot area I have a hollow knocking noise when you drive over a bump...ANY BUMP.
Today I think I have found it-taken spare wheel off and swing arm-the top bracket has a bit of play in it, bottom one is fine.
BUT the hinges are not bolted but have a huge rivet/bearing so cannot tighten up, short of drilling this out and replacing with a bolt don't know what to do
Sorry this is so long but has anyone else had same prob? the play in the arm with the weight of the wheel makes a very annoying noise which is amplified through the back door where the arm attatches
PLEASE HELP!!!!
PLEASE HELP!!!!
