hi gang..
my rig has been in the uk for nearly a couple of years now, and although still fairly clean underneath, the rear axle up to and including the ends where it bolts onto the wheel looks to have suffered from the weather a bit..it looks as though it needs a good wire brushing or sanding to clean it up, but i'm not sure whether to hammerite it or spray/brush some waxoil on..any other options on the market.
is this a common place for the tarnish to start on surfs, as it looks disproportionatly bad in that area..everything else, apart from the front wishbones and some 6 inches of front chassis section looks pretty clean..
