Hi All
Just sorted out my bump stops and spotted a leak from? a rubber flexable Flange?
If you put the steering on full lock there is a bar that runs parralle to the ground out from the wheel that has a a rubber flexable Flange on each end. It appears to be a flexable joint that has grease in and are held on with metal zip ties. (sorry have no manual to call them the propa name)
The one near the further under the truck has sprayed grease out
A couple or so questions..
1, Is it vital to sort
2, Would wrapping the rubber in gaffa tape sort it till I have time to replace it
3, It appears to be a lot of work to get too and replace
4, Where would you get a replacement/cost
5, Where do I top the lost grease/oil up from
Thanks for any help
Mark
Thanks for any help
Mark
You have the take the whole shaft out from the diff to the hub to strip it. Or pay someone to do it.
