hi all i wonder if there is anyone on here that can help a newbie out ? i need to locate someone that knows a fair bit about the mark 1 hilux 2wd basically my dad has brought a 1977/78 hilux camper van with a 2.0 ltr (20R) engine thats mated to a 4 speed gearbox, the clutch has burnt out damaging flywheel so looking to transplant another engine in (either more powerfull petrol or a diesel) trouble is info on what enginesfit etc. is a bit thin on the ground also need a 5 speed box for it so if anyone knows of the easiest engine/gearbox to fit this vehicle i would much value your input here hoping in anticipation cheers k.
help
Do you mean 2.2lt 20R if so I think the celica GT (think it was a TA22) was fitted with the same engine on a five speed boxOriginally posted by bigkhi all i wonder if there is anyone on here that can help a newbie out ? i need to locate someone that knows a fair bit about the mark 1 hilux 2wd basically my dad has brought a 1977/78 hilux camper van with a 2.0 ltr (20R) engine thats mated to a 4 speed gearbox, the clutch has burnt out damaging flywheel so looking to transplant another engine in (either more powerfull petrol or a diesel) trouble is info on what enginesfit etc. is a bit thin on the ground also need a 5 speed box for it so if anyone knows of the easiest engine/gearbox to fit this vehicle i would much value your input here hoping in anticipation cheers k.Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
on my celica koi which is a 1994 the model no.is E-ST202 and the engine is 3S-FE if this is any help forgot to say mine is the 2.0gtOriginally posted by KoiDo you mean 2.2lt 20R if so I think the celica GT (think it was a TA22) was fitted with the same engine on a five speed boxhttps://www.facebook.com/groups/henpals/
Originally posted by stormforce1067on my celica koi which is a 1994 the model no.is E-ST202 and the engine is 3S-FE if this is any help forgot to say mine is the 2.0gt
I think the model I was referring to is an older model than you currently have.Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
Toyota Engine InfoOriginally posted by KoiI think the model I was referring to is an older model than you currently have.
http://216.239.59.104/search?q=cache...tm+3S-FE&hl=en
I have a better link somewhere detailing uk models & engine types but can't find it at the moment.
Nevillef_________________
Nevillef
