egr
  • egr
    what is an egr valve and what does it do ??
    have tried a search but wont let me search with 3 letters
    cheers
    [img]http://www.click-smilies.de/sammlung0903/tiere/animal-smiley-022.gif[/img][img]http://www.click-smilies.de/sammlung0903/tiere/animal-smiley-022.gif[/img][img]http://www.click-smilies.de/sammlung0903/auto/car-smiley-006.gif[/img] [b][color=red]Anyone for [u]fluffy[/u] wheeltrims[/color][/b]
    Exhaust Gas Recirculation Valve
    Exhaust gas recirculation (EGR) systems were introduced in the early '70s to reduce an exhaust emission that was not being cleaned by the other smog controls. Oxides of nitrogen (NOx) are formed when temperatures in the combustion chamber get too hot. At 2500 degrees Fahrenheit or hotter, the nitrogen and oxygen in the combustion chamber can chemically combine to form nitrous oxides, which, when combined with hydrocarbons (HCs) and the presence of sunlight, produces an ugly haze in our skies known commonly as smog.
    So basically it recirculates some of the exhaust gases back in to the block to reduce NOx. It says in doing this it reduces the operating temperature of the block, I have read many many articles on this topic. Some written by the Green/environment people who advocate you should never disconnect the EGR because of the detremental effects it has on your engine, of course they would, nothing to do with the environment of course.
    Some by Profs. of motor mechanics, who don't deny in disconnecting the valve it raises the NOx levels released to atmosphere (our MOT laws in England don't test for NOx). They also claim that lowering the operating temperature is not a bad thing except the recirculated gases cause hot spots and on cast heads thats not good. The recirculated gases are reintroduced into the block on one side, so cooling that area not the far side of the engine, one side hotter than the other.
    The other down side of the EGR is, in reintroducing the gases back in to the engine, this will place an even greater demand on engine oil performance through increased soot generation and acid levels. So you need to make sure regular oil changes are strictly adhered to.
    The EGR also comes with another downside slight loss of power and decreased MPG.
    The very early valves (like on the early surfs) were single diaphram valves that open on positve pressure (some open on negative pressure) these early valves entailed a mass of vacuum hoses within the engine bay. They were not that reliable, hoses can rot, split, the diaphram within the valve can perish, become perforated. All this leads to a non or poorly operational valve.
    This system had many problems. It would often open to much, which caused a hesitation on acceleration as massive amounts of recirculated exhaust hit the combustion chamber. The peak temperature NOx is produced at only occurs when the engine is under full load, not all the time so with older style valves it recirculated all the time.
    The newer valves are controlled by solonoids, so control the recirculation better only reintroducing the gases when the engine is under full load. So are more reliable don't effect performance so much or the MPG.
    I have disconnected my EGR, I personally noticed more low down torque on my surf and better MPG. Yes my head has cracked 1 year after I got the motor and 10 months after disconnecting the EGR.
    There are some who's heads have cracked and have never disconnected the EGR.
    After replacing my head I reconnected the EGR for three weeks. Its diconnected again, couldn't stand the smoke it throws out the exhaust, the less grunt on acceleration and the worse MPG.
    I hope this answers your question with an unbiased opinion, there are the greens who write articles on the EGR saying how great it is and mechanics who write articles saying the early valves were poor.
    Thats the info, you make up your own mind.
    My 4x4
    My choice
    Back off
      Interesting reply. I would like to discoonect mine to see what difference it makes and being a novice in the ways of the Surf have no idea where to find it. Any photos or accurate directions how to find and disconnect it would be appreciated !
      Stephen
      1992 SSR-X Grey 2.4 TD Automatic
        Like this
        My 4x4
        My choice
        Back off
          Dumb Question
          Hi Koi
          Exellent reply and follow-up.
          Is it as easy as it seems.
          Eg: remove the vacume pipe from the ERG then blank off the redundent vacume pipe.
          Rubblebags.
          Rubblebags (Geoff).
            Originally posted by rubblebags
            Hi Koi
            Rubblebags.
            yep its that simple, i just folded the pipe over and used an electrical tie wrap to hold it in place. Others have used ball bearing, bolt anything that fits up the pipe and seals it up.
            A more permanant fix is to unbolt the recirc pipe from the EGR to the engine and fit a blanking plate in at the engine end, re fit pipe do up the bolts job done.
            My 4x4
            My choice
            Back off
              Originally posted by Koi
              Like this
              Splendid ! Much appreciated. I'll try it tomorrow and monitor it for a couple of weeks.
              Stephen
                thanks for the info i shall be disconecting tomorrow and see what happens
                cheers
                  Koi
                  Thanks for that info .Sorry the thanks is late Just got back on the pooter. today.
                  Rubblebags.
                  Rubblebags (Geoff).
                    dont expect the world though coz if yours is like mine ... well I blanked off the egr pipe at the air manifold with a beercan gasket and got no result at all - same heavy smoke same power, which means my egr wasnt working anyway and was already stuck closed.
                      Sorry to resurrect yet another ancient thread but I'm pretty sure that there isn't a blanked off part or dangling blocked pipe on mine. That said, it may well be shut closed by now.
                      As the thread is so old, the pics have gone. Anybody got a pic so I know what to remove and block off? Also, what about where the pipe was connected on the valve body? What happens to that?
                      Many thanks and apologies again..
                        Come and visit, I'll show you what to do.
                        I'm only up the A339, before you get to Amazingstoke.
