41:10 ratio front diff.
  • 41:10 ratio front diff.
    I've had a bearing weld to the front pinion gear in my KZN185; any advice on how to find one or how to proceed will be greatly appreciated.
    get numbers off old bearing and replace?
      might need to amend details of yur specific vehicle
      https://toyota.epc-data.com/hilux_su...240.1546554515
        Thanks for your help vortexwizard,
        I have purchased a bearing kit from RoughTrax hoping to find a replacement used diff.
        Unfortunately the bearing has picked up on the main pinion gear shaft; I thought of perhaps having it turned down and using a none standard bearing (smaller dia. inner) as I was a CNC Programmer/Setter/Machinist in a previous time, however the engineer who has stripped the diff. is not in favour of this?
        Plenty of new on eBay but no one shipping from Aus, NZ, USA and I cannot understand the Japanese sites (please don't mention Alibaba).
        At my wits end as to where to search next.
          Once you've got a part number from vortexwizard's link above, search for it on https://www.amayama.com/en. They ship from UAE and Japan, and I've used them quite a bit.
          https://galooph.com
