jacking points
  • jacking points
    due to the arrival of 4 nice new mud tyres and steel wheels i will need to jack up my 93 2.4 2nd gen to change the wheels, i have a hi-lift jack but i was wondering, where is it safe to apply the jack to get sufficient lift?
    thanks guys!
    matt
    thanks guys!
    matt
    Hmm - unless you've got strengthend sides I wouldn't bother. Better off doing it with either a bottle or trolley jack
    NO WORRIES!
    Rusty
      dont have a trolley jack, and how would i support my car witha bottle!!
      matt
        Assuming you genuinely didn't know he meant a bottle jack, he meant a bottle jack.
        You'll get plenty of lift with a decent bottle jack. Mine is a 4 tonne 387mm lift Draper one. Plenty of lift. €30 or so.
        Good luck,
        Mark
          Suggest either the front wishbones or rear axle as the safest bet both for you and the Surf!
          A positive attitude wont solve all your problems but it will annoy enough people to make it worth the effort!
            At the front I jack at the joint between the crossmember just fwd of the front diff and the lower wishbone. At the rear, under the diff.
            Are you sure you havent got a surf jack hidden beautifully under the rear seats.
            Doubt the hi-lift jack can reach in under to the chassis unless you've also bought rock sliders and few have
              matt
              Have a look under the rear seats, the bottle jack normally lives under there.
                heres a pic
                  cheers guys!
                  and for the record - i was not going to attempt to balance my truck on a bottle - milk, coke, beer or otherwise ;-)
                  was hoping i could use the hi-lift - just wondering where best to support it. but ill make do without for now
                  matt
                    cheers guys!
                    matt
                    There is nowhere to put a Hi lift on most 4x4s, unless you have the type of tow hitch that has a bar sticking out under the bumper.
                    Otherwise you need decent steel bumpers each end or sliders instead of side steps.
