Beefing A Rear Axle & Adding Disc Brakes
  • Beefing A Rear Axle & Adding Disc Brakes
    This looks rather interesting...
    http://www.4wheeloffroad.com/brandpa...131_0307_disc/
    AndyL
    Rear discs are good, got all the stuff collected in the garage. No more drums full of mud.
    But you'll never brake a rear shaft the way we wheel in this country, you need dual t/cases, lockers and big rocks to do it.
      Not only the advantage of having disc brakes, but a fully floating rear axle means servicing the rear bearings a doddle - pack and regrease or changing them is so much easier than replacing the standard type rear wheel bearings on a Semi floating axle - plus it's much stronger.
        Just read the review on these here > http://www.4x4wire.com/toyota/reviews/fullfloater/
        Do they fit the coil spring Surfs?If they do I want it.
        Neville
          Neville
          You should have the same axle, just different spring fittings.
          Yes its cool, and yes I'd like one, but its a bit over the top unless your competing in rockcrawling events, having to buy new axles makes it expensive, No one I know has ever broken an axle shaft, or bearing while offroading.
          The best bit is if you run a locker, and break an axle shaft, you can unlock the hub and drive home
          Personally I'd just fit the discs and leave the axle alone, and worry about uprating the CV's a long time before needing to sort the rear out.
