happy new year to all!
now my u-joint woes...
When I replaced rear-joint on rear prop a month or so ago, I messed the job, and damaged the roller needles... so had to get another new u-joint.
After installing this I discovered one of the cups was rotating withinin the prop assembly where it should be pressed, so I used some metal glue to stop that. Everything seemed OK and secure,
but I have now noticed the u-joint is loose-worn again... arghhh....
guess I might be needing a whole new prop?, how much are these? and where for a KZN130?
this might also be a good idea as there is rotational AND vertical play in the yoke-sleeve section - suggesting thats also worn
