u-joint woes...
  • u-joint woes...
    happy new year to all!
    now my u-joint woes...
    When I replaced rear-joint on rear prop a month or so ago, I messed the job, and damaged the roller needles... so had to get another new u-joint.
    After installing this I discovered one of the cups was rotating withinin the prop assembly where it should be pressed, so I used some metal glue to stop that. Everything seemed OK and secure,
    but I have now noticed the u-joint is loose-worn again... arghhh....
    guess I might be needing a whole new prop?, how much are these? and where for a KZN130?
    this might also be a good idea as there is rotational AND vertical play in the yoke-sleeve section - suggesting thats also worn
    Landcruiser Colorado
    Sub. Forester
