Saggy Arse
  • Saggy Arse
    ok i,m confused with this saggy arse syndrome is it the springs i,ve got to change or the shocks on the back help
    SPRINGS
      Yep I had the saggy arse syndrome and got the 20% stronger springs from Milners....No more saggy arse and the car has less tendency to kick its backside out going round corners
      Gaz
        thanks looks like i shall have to invest in some cheers folks
          Here is a way to check for sagging rear end.With the vehicle unlaiden get under the rear and look at the distance between bump stops and rear axle housing.I am not sure of the original measurements but if they are like mine were before replacing springs and shocks they will be bottoming out and you will see a shiny patch under the bump stops.Mine were down to around 30mm gap.I now have around 80mm.
          Neville
            i found a good pair of hold up knickers and tight jeans helped my sagging arse
            lets go get dirty...
              pmsl
              1992 hilux surf ssr-x 2.4 auto 2nd gen LN130
              http://cornishhostingcompany.co.uk/support/aff.php?aff=005
                Wow! Almost 6 years...
                  god yeah it is as well lol didnt notice the date
                    seaarch button succeeds again!
                    cant decide which are better...the roughtrax springs or milners?
                    milners are cheaper
                    anyone bought either?
                    My Surf eats knuckles for breakfast!
                      milners are cheaper
                      hi i bought milner springs and had them renewed thru warranty only 6 mouths after they were fitted ive been told the roughtrax ones r better as they have the 2" lift as standard but not all have noticed a lift in height but they have said they last well
