ok i,m confused with this saggy arse syndrome is it the springs i,ve got to change or the shocks on the back help
Saggy Arse
Here is a way to check for sagging rear end.With the vehicle unlaiden get under the rear and look at the distance between bump stops and rear axle housing.I am not sure of the original measurements but if they are like mine were before replacing springs and shocks they will be bottoming out and you will see a shiny patch under the bump stops.Mine were down to around 30mm gap.I now have around 80mm.
Neville
i found a good pair of hold up knickers and tight jeans helped my sagging arseOriginally posted by smnsparkok i,m confused with this saggy arse syndrome is it the springs i,ve got to change or the shocks on the back help
lets go get dirty...
hi i bought milner springs and had them renewed thru warranty only 6 mouths after they were fitted ive been told the roughtrax ones r better as they have the 2" lift as standard but not all have noticed a lift in height but they have said they last wellOriginally posted by che2318 View Postseaarch button succeeds again!
cant decide which are better...the roughtrax springs or milners?
milners are cheaper
anyone bought either?
1992 hilux surf ssr-x 2.4 auto 2nd gen LN130
http://cornishhostingcompany.co.uk/support/aff.php?aff=005
