I have a problem (well I have several but only one you lot are likely to be able help with) No 4WD, I've tried Hi and Lo and it's still possible to turn the front prop. I've traced all the vacuum lines I can find and they seem fine. As when I press the button nothing at all happens; no click of a relay, no light no buzz so I suspect (hope) an electrical fault but can't find a fuse labelled 4WD either under the bonnet or in the foot well, does it share a circuit with something else or is it hidden away? I gather the motor / solenoid (which is it??) on the back of the transfer case can stick, might this blow a fuse? How do you free it off?
Here's hoping
Matt
Here's hoping
Matt
