Can someone please advise me on this noise??
Just driven 4 hours solid on the motorway, checked oil and everything before I set off. As I reached my destination, the front end started making a real high pitched grinding metal noise. Pulled over immediatley, the engine is running fine, all the wheel nuts are on tight, and the noise is when travelling straight and when cornering. Drives fine, steering is fine - no crunchiness. Temp and oil pressure is fine. The noise is not constant but sounds very bad.
Can anyone tell me what this is? It sounds wheel related but seems to come from both sides. Is it wheel bearings??
Anyone know what this is?? and does anyone know a good garage in Derby??
but have heard that brake pads make an orrible noise when they are low, have you checked them?
