could someone tell how to get the plastic face off the instrument cluster i only need to clean it, looks like whoever converted the speedo face splilt something down the inside
instrument cluster
methinks you will have to remove the upper dash, link on how to do it :http://www.showmesome.info/hilux/workshop/dash.htm[FONT=Franklin Gothic Medium][COLOR=Magenta][SIZE=2][B]SEWERAT BOB[/B][/SIZE][/COLOR][/FONT]
[SIZE=3][COLOR=SeaGreen][I][COLOR=Lime][B]I just sit here & looks out to sea or if i'm really rushed then i just sits here & continues to look out to sea[/B][/COLOR][/I][/COLOR][/SIZE]
Even when you get the intrument cluster out, you can't split the unit except very carefully with a sharp knife - the plastic is stuck on the front of the unit. Alternaive is to remove the guages and the circuit board and go in from behind, might be able to clean it that way.Originally posted by cuz 62could someone tell how to get the plastic face off the instrument cluster i only need to clean it, looks like whoever converted the speedo face splilt something down the inside
