Calling all leccy aerial wizards.
My leccy aerial is working ok in so much as it goes up when I switch the radio on but the motor runs on a bit when it reaches the top. When I switch the radio off, or the ign, the motor runs but the aerial wont go down until I give it a gentle tug then it goes all the way down and the motor stops. If I switch off before it reaches full extension it will go back down again? It's as if it might be going up too far?
I have sprayed it with WD thinking it was sticking but theres no difference.
Am I stuck with helping it to retract or can it be fixed?
