I have recently developed a fault;
The 4wd light just flashes on the dash when the 4wd button is pressed.
I checked the vacuum and that side of things is fine, I can get the 4wd to function if I switch the vacuum pipes over on the actuator.
The fault seems to be that there is no power to the blue connector that operates the vacuum to engage the actuator.
Also the power is constantly on to the orange connector, meaning the 4wd is constantly disengaged.
I have checked the wiring, checked the function of the switch on the front actuator. All working fine.
The switch must work fine as the light only comes on when the switch is pressed.
Anyone got any pointers?? or even better anyone got a wiring diagram?
