Been out again trying to work out my electric 4wd/2wd system which won't disengage and came across this solenoid vacume thingy. It has what looks like two little air filters on the bottom ends and block connectors (one brown, one blue) then various air tubes heading into the bowels of the truck.
I took both connectors off to check if they were clean and both were, but when re fitting I noticed with ignition on the blue connector would make small electric crackle noises so guess it works fine. However the brown one was silent, no noise but just clipped back in.
Are these related to the electric ADD system? Can new ones be bought if broke? This Toyota electric mallarchy is a mine field haha. Cheers, Tom
