Hello all, quite a while ago my headlights stoped working. The parking lights work but when I flick the swich to low beams nothing (even the parking lights turn off). The bulbs are new and working. i tested the relay and it works, and no fuses are blown. I have also checked the switch and it works perfectly.
when i flick the switch to low beam, i can hear a non-pattered random click in the fuse box under the dash (kinda like a indicator light click but random). i tried feeling the relays to see which was clicking and it was the round relay, manual says tail light relay. so i removed the relay and tested the signal terminals (1 & 2). when i put the switch to parking lights only, i get a normal 12v reading. but when i flick it to low beams (or push to high beams) the voltage drops to about 2.9~3.1v and the head relay under the hood starts to make a buzzing noise.
i am really confused. what seems to be the probelm?
edit: when i pull for the flashers, i get a 0v reading at the terminal (normal behavior I believe) but the head relay under the hood buzzes. i have noticed that it only buzzes when the tail light relay is removed.
