LED headlights....or is it?
  • LED headlights....or is it?
    hello again,
    i had ordered 2 sets of headlights for the surf from Dubai. on my order i have told the guy that I would like them to be LEDs.
    well the headlights arrived yesterday, and unfortunately they are normal halogen bulbs. But wait...there are these 4 LEDs in another plastic bag. (I have tried to attach a photo)
    Now I'm thinking if the halogen glass can be removed from the case and replaced with those leds. What do you think?
    '94 Surf SSR-X --3.0l Turbo-KZN130W -- 400,000KMs
    in case you could do that, which leds are hi, and which are low beam?
      oh ya...the connector is 3 pin but the LEDs have only two. what a bummer!
        The led bulbs above are sidelight bulbs.
          they look bigger than a t10
            they are not sidelight bulbs, theh are much bigger
              this one is hi/low beam
              http://www.gearbest.com/car-lights/pp_203700.html
                send em all back, no use to you. Those old style smd chipsets are not very bright.. The fitting is the same as an indicator rather than a sidelight.
                  i cant send them back (its complicated). all is not bad though, becuase the new halogen bulbs are much much brighter than the old tired ones. i might fit the LEDs as an auxiliary light after I purchase some reflector hosuings.
                    I have those leds as reversing bulbs, no where near bright enough for headlights!
