So I recently got a new job which now means I am a commuter again, and because it's winter my commute home is in the dark. I've always found the headlights in the Surf to be pitiful (who doesn't?), but I couldn't put up with it any longer (11 years a Surf owner
). I came across these LED H4 bulbs while searching for something completely unrelated, and figured I'd give them a go.
http://eu.banggood.com/Wholesale-War...k-1015078.html
(I've ordered loads from BangGood with no issues. Can be slow if you order from the China warehouse though, but EU is pretty good)
Ordered them on the 4th, they arrived on the 9th, and due to the weather I only managed to get round to fitting them today.
Usual palaver with changing the bulbs on a Surf, remove the batteries, then the washer bottle on the left, and the expansion tank and air guide on the right to get to the back of the lights. The new bulbs are a bit longer because of the heat sink on the back, but there is plenty of room to fit them. One downside however is that the rubber gasket doesn't fit, so if you off-road a lot in deep water then these bulbs won't be for you. New bulbs in, everything back together. Total job time about 30 minutes.
What. A. Difference. The pictures don't really do them justice. The new LEDs are obviously pure white rather than yellow, and they're nice and bright. This should improve my drive home no end.
One bulb changed for comparison:
Both bulbs done, rain setting in:
For £33 delivered, I'm very happy.
Going to have to do something about the sidelights now, they look pitiful next to the mains.
