Ok chaps, searched the forum with no clues as to my particular problem, so hopefully one the fonts of wisdom around here can help
So on my 2l SSR-G I have a factory loom for front spots which I plugged my new spots into. There is an isolator switch in the centre console (again, factory fitted) and with this on, the spots don't power up until I switch on sidelights or main beam. So I'm picking there is a relay already fitted and my question (finally!) Is.....how do I change the switching so that spots only come on with high beam whilst keeping the isolator switch as part of the circuit? I'm assuming I just need to change the connection at the relay but any idea where the relay would be and which wire/terminal would be responsible for switching?
I don't see a need to do a re-wire, surely I can just change the switching circuit at relay, or add a new relay???
