Until recently whenever I've brimmed the tank the fuel gauge has read a bit over the 'F' mark. However the last two tanks that I've brimmed it the gauge reads about an 1/8th under the 'F' mark. I also ran that last tank all the way down until the low fuel light came on, and it was a very long way under the 'E' mark. It's almost as if the gauge had moved down an 1/8th or so.
I know the gauges aren't exact things, but this is markedly worse than it was before now. Anyone got any ideas what might be causing this?
