Greetings, and apologies for yet another thread on this.
The rear window (2nd gen) is stuck up.
Has been working fine from inside, and usually ok with the key, though sometimes I need to turn it back and forth once before it would work.
I'm getting a relay click from the button in down position.
Volt meter reads 12v at the motor plug with ignition on, and drops to 0 when pressing the button. Swapping the meter round gives 0, but a few volts briefly after pressing the button.
I'm thinking it's the motor as the relays seem to be doing something.
Can anyone confirm before I rip bits off?
Thanks folks.
Bazza
Thanks folks.
Bazza
