Hi all. I've had a search through the threads and found similar problems but not the same one. Also, I've put this in electrical but it may possibly be a mechanical problem, so if it is would someone move it please.
Now the problem.
If I use the key in the drivers door to unlock it, all of the doors lock and unlock. If I use the button on the armrest, all of the doors lock and unlock except for the drivers door. I also fitted a remote entry system and if I use this, the same thing again, all of the doors lock and unlock except for the drivers door.
Does this sound like the actuator has gone kaput or is it likely to be a wire broken somewhere?
Thanks in advance.
					Now the problem.
Thanks in advance.
no probs.
