As some of you may be aware I have a bit of a passion with vehicle electrics and toys to go in the wagon.The existing systems allowed me to link / charge the two main batteries, in addition allowed for the charging of the Auxiliary battery which powers the radios etc while the vehicle is turned off. The new systems are basically add-on modules to the existing bits, and like them the are designed and made by me.
A digital display indicates battery voltages individually selected or the main battery as default.
Now all of the accessory power for CD player CB, UHF, Scanner etc all comes from one place and is selectable between the vehicle power if engine is running or auxiliary power.
The very cool part is the solar panel which charges each or all of the batteries. At 50mA it is not a lot however it is enough to tickle the batteries while parked for extended periods.
The third power supply is a charge input that will run in parallel to the solar panel and allows the vehicle to be plugged in to any “home” 230VAC supply, this provides up to 1A charging if required.
The standby power supply/jump starter in the back is still there and I hope not to need it in a hurry!!
All in all I now have a lot of power going all over the place and the ability to do almost what I like with it.
