Heater Lights Dim with sidelights
  • Heater Lights Dim with sidelights
    I have only recently noticed that when I turn on the sidelights, the dash lights in the heater panel dim considerably to the point they are hardly visible. Is this a known fault and does anyone know the cause?
    It's a 3rd Gen single battery set up. Thanks
    Bad earth somewhere?
      Earth?
      Any idea where? It affects the clock too but I imagine its a side light issue rather than a gauge illumination issue.
      Annoying, maybe I will just swap to the car I'm selling - that one seems to give me less grief at the moment!
        If it's something to do with the sidelights, check there first, could be corrosion of the sidelight bulb terminals
          Not an earth fault
          Ok, this affects my brother in laws surf too! I have so far removed the dash, including all plugs, plus the clock and heater panel plugs. I have given each a new earth in turn and it makes no difference - there is clearly a considerable drop in power when the sidelights are on which in my mind would not be an earth fault. I have also given the sidelight stalk switch a new earth - also making no difference. It appears that all the sidelights have their own seperate earth points so I am wondering if this is a switch issue. Someone else must have come across the same problem!
            You sure it's a fault? Is it not by design?
            Сви можемо
              x2
                All single battery Surfs are the same as yours, the clock and heater lights dim when the sidelights are switched on to save battery power.
                Fit an additional battery if you want brighter dash lights.
                  And there I am ripping the connectors off everything! Thanks - another mystery solved. Now on to the rev counter...
