I've searched but only seem to find posts about the rear window motor not working.
My rear window is fixed & rear hatch folds upwards. The rear wiper/washer doesn't work any more nor does the screen heater. I'm just wondering if there is some additional fuse for this supply? All the fuses under the bonnet & by the accelerator pedal are intact.
I notice the push button on the dash for the rear screen heater doesn't illuminate nor stay down for the timer to operate. Nor does it light up if I hold it down doesn't seem to latch.
I suppose if the is no additional fuse the most likely place is failure in the cable or connectors nearest the hinge.
Weather rather foul at present, just want to have an action plan before I get soaked too much!
Many thanks
Many thanks
