Here is one for the electrical gurus.
2.4 radiator fan, the one controlled by the thermo switch under the thermostat.
The fan will randomly start and stop with no regard to coolant temp.
The fan will also vary its speed going from pulsing on off to a fairly low speed to full speed.
If I apply battery power to it the fan is at full speed.
If I remove the thermo switch the fan speed is full speed.
If I stick a meter on the thermo switch contact spade I get 5 volt to earth.
I'm assuming that the fan feed to the relay is earthed out via the thermo switch making the circuit, so would a sticky relay give me the 5 volts at the thermo switch?
Ta
Ta
