Does anyone know where I can get an ECU For my KZN-185
Needs to be a 89661-3D240
I sent it to BBA REMAN and they said they can't test it , had the same problem for couple of months now nothing will read the ECU
If I bridge the diagnostic terminal just keeps coming up code 14 (timing control valve ) I've replaced my 7070 fuel pump engine runs sweet until light comes on and puts it into limp mode ( no power at all )
I've had engine checked and everything's as it should be but lights on and timing goes out ever so slightly cos it knocks a little when I turn the engine off ! ,
