As you know there is an electric fan infront of the radiator behind the grille. Based on my research I found out that its used for the A/C condensor. But since my A/C condensor or A/C compressor or A/C on-off switch dont work, its just sitting there. So I wanted to make use of it and mod it as a secondary helper fan to the main fan. I did wire it directly and it works fine, but its pointless. I want it to be on when the engine is running and I want the line to have some kinda protection (a fuse or something). And also, ajacent to the main fuse box there is another housing which holds two relays (CDS Fan No 1 and CDS Fan No 2) and a 30AMP CDS fuse. I wanted to make use of those since they are there, if possible.
can anyone guide me through the process or direct me to a good link.
p.s. my electrical skills are not enough so a detailed one will be hugely appeciated.
