Hi all!!! I'm a new owner of a '93 2.4 TD Auto Surf SSRX and as I was driving it home from the yard, I pressed the 4WD button on the Transfer lever, from H2 - H4 and apparently it engaged in 4WD but pressing it again to disengage, did nothing!!! The 4WD light stayed on, on the dash and when I got it home and tried to reverse, found out it was still engaged!!! Is it an electrical fault (switch) or is it a more serious fault??? No matter what I do it stays on! The only time it turns off is when I put the 4WD lever in neutral position and disengage the whole lot!!! Can anyone pleae shed some light on a new owner of this fabulous 4WD???
Regards Ian
Regards Ian
All smiles now!! It took about 4 or 5 times to unlock the hubs. They wound themselves quite tight I think. But all is well now, thanx to your info!! But we had to reverse about 20-30 metres and swinging the steering from side to side to unlock them! Luckily no noticeable damage, yet!
It's all fixed now!!! The local 4X4 mechanic reversed it for about 50 metres, swinging the steering from side to side. After about 4 or 5 times it released itself
Luckily enough no damage was done!!! Thanx for all the info!!!
