Hi All, just a quickie, does the inhibit link in the rear wiper stop the rear window from going up and down or just down?
rear window inhibit switch
Hi vinceOriginally posted by BUSHWHACKER View PostJust down as far as I know.
The lock button next to the tailgate release handle must be down to allow the window to raise. It should do it automatically as you turn the key.
I meant the inhibit on the wiper, the window goes up via switch and key but not down....still the original problem! the motor is fine up and down with a direct feed, I wondered IF it could be anything to do with the wiper park sensor, before I get the trim and relay out AGAIN....am slowly loosing the will to live!!Did I mention I have a BLUE one
Tony
