Rear passenger window stopped working yesterday and I took the door apart to have a look.
When I unpluged the motor I tested the circuit and got 12 volts from the socket, but when the motor is plugged in I got nothing from the 2 wires even after I took the motor plug off and stuck the 2 wires into the socket.
Does this mean it's earthing somewhere? never thought about that when I had it apart or is the motor just fubar
have undone the motor from the door and rotated it round so the window is now closed and held the motor in place with cable ties and duck tape (used to have a landie)
Is it a difficult job to fit new motor? as I can't see how you can get at every thing
