Hey guys,
I've scoured through the forum in an attempt to fix my aerial. I whipped out my old one and replaced with a second hand motor from the breakers. Everything seemed to go well until the aerial didn't go back down, at first I thought it was a duff motor. So i put some testers across the plug underneath the wheel arch which was showing 12v. So I plug the aerial back in only for it to spew the entire rod+track out. Even with the radio and ignition off there is still 12v at the plug causing my aerial to run constantly.
Any help would be appreciated, cheers.
